UrlResolver.Current.Route returns null when in backoffice
I'm using a UrlBuilder extension to handle some images. However the UrlResolver.Current.Route returns null when I preview in the backoffice.
The target.Path in backoffice is "/EPiServer/CMS/Content/globalassets/en/about_us_1100_1620.jpg,,50926" - but I'm guessing this is already a contentreference?
The target.Path outside backoffice is "/globalassets/about_us_1100_1620.jpg" and this have no problem converting to a contentreference.
How can I fix this so I can use it both in backoffice and "outside"?
One way is to split the target.Path on ',' and use "new ContentReference(int.Parse(splittedValue[1]))" but that seems ugly. Any nicer solutions?
if (target == null || target.IsEmpty)
	throw new ArgumentNullException(nameof(target));
var content = UrlResolver.Current.Route(new UrlBuilder(target.Path));
if (content == null)
if(ContentReference.IsNullOrEmpty(content.ContentLink))
ImageFile imageData;
try
	imageData = ContentRepository.Service.Get<ImageFile>(content.ContentLink);
catch (TypeMismatchException)
return imageData;
#206401
Aug 20, 2019 8:15
Hi Carl,
I think I need a little more context to work out what's going on here.
What is target? I feel like it must be a UrlBuilder based on the Path and IsEmpty properties. Also, presumably the editor is selecting this image in the CMS? What property are you using—a ContentReference, a Url, a LinkItemCollection or something else?
#206415
Aug 20, 2019 17:20
Hi Jake,
Yes, UrlBuilder and a ContentReference.
// Carl
#206428
Aug 21, 2019 6:54
Is there a reason you don't just get the ImageFile from the the ContentReference directly? This seems a very roundabout way to get there.
#206450
Aug 21, 2019 15:18
Yes. I use ImageResizer:
@Html.ResizeImage(Model.VerticalImage.Image).Width(700).Height(1031).FitMode(FitMode.Crop)
And I have to use my code as an UrlBuilder extension.
#206451
Edited, Aug 21, 2019 15:21
I suppose when you initally resolve the URL you could ensure you never get the edit mode URL by specifying UrlResolverArguments, something like:
var url = _urlResolver.GetUrl(page.PageLink, ContentLanguage.PreferredCulture.Name,
    new UrlResolverArguments {ContextMode = ContextMode.Default});
Honestly, I feel like there still must be a better approach, maybe adding a new overload method for ResizeImage since that takes in a ContentReference already?
#206452
Aug 21, 2019 15:53
I don't have access to the Resizer original extension and the Html.ResizeImage takes a ContentReference.
#206456
Aug 21, 2019 16:30
Would you need to change the original? Maybe you could just do something like this (untested) example:
public static class HtmlHelperExtensions
    static Injected<IContentRepository> ContentRepository { get; set; }
    public static UrlBuilder ResizeImageCustom(this HtmlHelper helper, ContentReference image, int? width = null, int? height = null)
        if (ContentReference.IsNullOrEmpty(image))
            throw new ArgumentNullException(nameof(image));
        ContentRepository.Service.TryGet(image, out imageData);
        var urlBuilder = helper.ResizeImage(image, width, height);
        if (imageData != null)
            // Do whatever needs to be done.
        return urlBuilder;
#206457
Aug 21, 2019 16:46
we need to change originals :)
#206559
Aug 24, 2019 0:58
