Adding premium plugins like LinkChecker to Episerver's TinyMCE
Hi all,
We have obtained a premium license for TinyMCE to be hosted on premises.
We would like to add some of the premium plugins that were included in the license into the WYSIWYG editor for our content authors to use, specifically linkchecker and spellchecker.
Does anyone know how we can achieve this?
Cheers,
Raquel
#206264
Edited, Aug 09, 2019 7:16
Praful Jangid
You can refer TinyMCE editor cutomization documentations here (additional links on that page too for more configuration information).
https://world.episerver.com/documentation/developer-guides/CMS/add-ons/customizing-the-tinymce-editor-v2/plug-ins/
It will help you to add plugin in TinyMCE.
#206267
Aug 09, 2019 9:05
Any specifics please?
I have added the following into CustomTinyMCEInitialization and also added the linkchecker folder into same folder of tinyMCE in modules\_protected\EPiServer.Cms.TinyMce but doesn't seem to be having any effect.
private const string Plugins = @"code epi-link epi-image-editor epi-dnd-processor
epi-personalized-content print preview searchreplace
autolink directionality visualblocks visualchars linkchecker
fullscreen image link media template codesample table charmap
hr pagebreak nonbreaking anchor toc insertdatetime advlist lists
textcolor wordcount imagetools contextmenu colorpicker textpattern help";
config.Default()
.Width(0)
.Menubar("file edit insert view format table tools")
.AddPlugin(Plugins)
#206268
Edited, Aug 09, 2019 9:34
Praful Jangid
Here is an example from my working site.
    context.Services.Configure<TinyMceConfiguration>(config =>
        config.Default()
            .AddEpiserverSupport()
            .AddPlugin(DefaultValues.EpiserverPlugins, "code contextmenu")
            .Toolbar("bold italic underline strikethrough subscript superscript epi-link code");
#206270
Aug 09, 2019 9:42
The other plugins on our site also works except for the LinkChecker. I will be interested to know if anyone has added a premium plugin for TinyMCE separate from the other free plugins.
We have also done custom plugins which were fine so not sure why the premium linkchecker for TinyMCE is not working.
#206271
Aug 09, 2019 9:48
- Aug 09, 2019 10:02
Have you tried these configuration documentation?
https://www.tiny.cloud/docs/plugins/tinymcespellchecker/
Check the Self Hosted installation in above link.
It sounds like difficult configuration steps (see below link)
https://www.tiny.cloud/docs/enterprise/server/
Ravindra S. Rathore
Hey Raquel,
Please refer below article from Episerver-
https://world.episerver.com/add-ons/spellchecker-for-tinymce/configuring-spellchecker-for-tinymce/
Ravindra
#206288
Aug 12, 2019 9:17
Ravindra S. Rathore
Hey Raquel,
Are you able to resolve this issue?
#206364
Aug 16, 2019 13:55
We haven't had any luck with this so far. Contacted App Services at epi and the advice is to use epi's tinymce plugins. However, they don't have an equivalent plugin for tinymce's linkchecker.
Epi also recommends getting the same version of the plugins for the built in tinymce. However, as our CMS version uses 4.7.13 and tinymce advised us that they can no longer supply plugins for this version, not sure what to do.
I've tried installing the 4.9.4 plugin into the epi tinymce instance but it doesn't seem to work for me.
#206384
Aug 19, 2019 8:09
Any update on How to include Premium Plugin like powerpaste to Episerver TinyMCE?
#206653
Aug 28, 2019 11:37
We have contacted someone from epi's expert services who said that for this to be self-hosted, we would have to install a TomCat server to host it and point to it so we can use it. It is apparently a complex process and we haven't had the chance to do it yet in our environment. Just hoping that this might point someone else who is having a similar issue to the right direction! If anyone else has done it and can provide better instructions, it'll be much appreciated!
#206705
Aug 29, 2019 1:21
- Aug 29, 2019 7:49
Thanks Raquel!
One more question: Can't I directly use .AddExternalPlugin method If I have the premium-plugin js file?
Example:
config.Default()
.AddExternalPlugin("custom-plugin", "alloy/plugins/custom-plugin.js");
Raquel - Aug 29, 2019 7:54
I tried that but that didn't work for me
- Aug 29, 2019 7:55
Thanks Raquel!
Raquel - Aug 30, 2019 4:48
TinyMCE came back and told us that some of the plugins like LinkChecker and SpellChecker have server side components.
I'm guessing that other plugins would only be client-side then and will work by using .AddExternalPlugin method. Try it as it may work depending on the plugin you are after.
