Restrict access to table properties option in the TinyMCE Table plugin
Hi all,
Is there a way to restrict access to a specific option in the TinyMCE table plugin menubar.
In reading the TinyMCE documentation (https://www.tiny.cloud/docs/plugins/table/#table_toolbar, https://www.tiny.cloud/docs/configure/editor-appearance/#menu), it should be possible, but I can't figure out how to make it work with the Episerver configuration initialization.
Joe Mayberry
#205980
Jul 30, 2019 16:38
Ravindra S. Rathore
Update:
I wasn't able to find a way to  remove the table properties option in the menu bar. However, I was able to hide most of the options in the table properties using the table_ settings in the config initialization, then enabling them if the user is in a specific set of roles. Not a perfect solution, but one that looks like it will work.
TinyMCEInitialization.cs
using EPiServer.Cms.TinyMce.Core;
using EPiServer.Framework;
using EPiServer.Framework.Initialization;
using EPiServer.ServiceLocation;
namespace Website.Business.Initialization
    [ModuleDependency(typeof(TinyMceInitialization))]
    public class ExtendedTinyMceInitialization : IConfigurableModule
            var customSettings = new Dictionary<string, object>
                    "extended_valid_elements",
                    "section[*],&[*],i[*],div[*],a[*],span[*],script[*],style[*],iframe[*],container[*], h3[*]"
                    "valid_children",
                    "+a[img|h1|h2|h3|h4|h5|h6|p|span|div|i|noscript], +span[a|h1|h2|h3|h4|h5|h6|p|span|i|div|noscript], +div[a|h1|h2|h3|h4|h5|h6|p|span|i|div|noscript]"
            context.Services.Configure<TinyMceConfiguration>(config =>
                config.Default()
                    .Menubar("file edit insert view format tools")
                    .DisableMenubar()
                    .AddEpiserverSupport()
                    .AddPlugin("epi-link epi-image-editor epi-dnd-processor epi-personalized-content epi-image-tools print preview searchreplace autolink directionality visualblocks visualchars fullscreen image link media template code charmap hr pagebreak nonbreaking anchor toc insertdatetime advlist lists textcolor wordcount imagetools contextmenu colorpicker textpattern help anchor")
                    .Toolbar("styleselect formatselect | bold italic | cut copy paste pastetext removeformat | epi-personalized-content | fullscreen",
                        "bullist numlist outdent indent | alignleft aligncenter alignright | table | epi-image-editor epi-image-tools image media epi-link unlink anchor | epi-dnd-processor")
                    .RawSettings(customSettings)
                    .ContentCss("/Static/Assets/css/editor.css")
                    .AddSetting("invalid_styles", new { td = "width height", tr = "width height", th = "width height", table = "height" })
                    .AddSetting("table_default_attributes", new { border = 0 })
                    .AddSetting("table_default_styles", new { borderCollapse = "inherit", width = "100%" })
                    .AddSetting("image_title", true)
                    .AppendToolbar("table")
                    .AddSetting("table_appearance_options", false)
                    .AddSetting("table_advtab", false)
                    .AddSetting("table_row_advtab", false)
                    .AddSetting("table_cell_advtab", false)
                    .AddSetting("table_resize_bars", false);
EditorDescriptor.cs (role check)
using System;
using System.Collections;
using System.Linq;
using EPiServer.Core;
using EPiServer.Shell.ObjectEditing.EditorDescriptors;
namespace Website.Business.EditorDescriptors
    [EditorDescriptorRegistration(TargetType = typeof(XhtmlString), EditorDescriptorBehavior = EditorDescriptorBehavior.PlaceLast)]
    public class CustomXhtmlStringEditorDescriptor : EditorDescriptor
        public override void ModifyMetadata(EPiServer.Shell.ObjectEditing.ExtendedMetadata metadata,
            IEnumerable<Attribute> attributes)
            var userInRole = PageUtilities.IsInValidRole;
            if (userInRole)
                var settings = metadata.EditorConfiguration["settings"] as Dictionary<string, object>;
                if (settings != null)
                    var toolbarList = ((IEnumerable)settings["toolbar"]).Cast<string>().ToList();
                    if (toolbarList.Count > 1)
                        toolbarList[1] = toolbarList[1] + " | code";
                    settings["toolbar"] = toolbarList;
                    // Table properties
                    settings["table_appearance_options"] = true;
                    settings["table_advtab"] = true;
                    settings["table_row_advtab"] = true;
                    settings["table_cell_advtab"] = true;
                    settings["table_resize_bars"] = true;
#206057
Aug 01, 2019 14:59
