Hey Eric,
Can you cross check with the System Requirement Documents that version is not an issue and are supported?
Also, here is a related thread (might be helpful)
Praful
Error saving any page after .Net Framework update and using VS2019. This error does not happen on our previous version of .Net Framework using VS2019.
The parameters dictionary contains a null entry for parameter 'action' of non-nullable type 'EPiServer.DataAccess.SaveAction' for method 'System.Web.Mvc.ActionResult ChangeStatus(EPiServer.Core.ContentReference, EPiServer.DataAccess.SaveAction)' in 'EPiServer.Cms.Shell.UI.Rest.Internal.ContentDataStore'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
Parameter name: parameters
Exception Details: System.ArgumentException: The parameters dictionary contains a null entry for parameter 'action' of non-nullable type 'EPiServer.DataAccess.SaveAction' for method 'System.Web.Mvc.ActionResult ChangeStatus(EPiServer.Core.ContentReference, EPiServer.DataAccess.SaveAction)' in 'EPiServer.Cms.Shell.UI.Rest.Internal.ContentDataStore'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
Source Error:
Stack Trace:
[ArgumentException: The parameters dictionary contains a null entry for parameter 'action' of non-nullable type 'EPiServer.DataAccess.SaveAction' for method 'System.Web.Mvc.ActionResult ChangeStatus(EPiServer.Core.ContentReference, EPiServer.DataAccess.SaveAction)' in 'EPiServer.Cms.Shell.UI.Rest.Internal.ContentDataStore'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
Parameter name: parameters]
System.Web.Mvc.ActionDescriptor.ExtractParameterFromDictionary(ParameterInfo parameterInfo, IDictionary`2 parameters, MethodInfo methodInfo) +430
System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +111
System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35
System.Web.Mvc.Async.<>c.<BeginInvokeSynchronousActionMethod>b__9_0(IAsyncResult asyncResult, ActionInvocation innerInvokeState) +39
System.Web.Mvc.Async.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult) +70
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) +42
System.Web.Mvc.Async.<>c__DisplayClass11_0.<InvokeActionMethodFilterAsynchronouslyRecursive>b__0() +80
System.Web.Mvc.Async.<>c__DisplayClass11_2.<InvokeActionMethodFilterAsynchronouslyRecursive>b__2() +387
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) +42
System.Web.Mvc.Async.<>c__DisplayClass3_6.<BeginInvokeAction>b__4() +50
System.Web.Mvc.Async.<>c__DisplayClass3_1.<BeginInvokeAction>b__1(IAsyncResult asyncResult) +188
System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +38
EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult) +60
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +648
System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +213
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +131
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.3282.0
________________________________________
Value cannot be null.
Parameter name: user
Exception Details: System.ArgumentNullException: Value cannot be null.
Source Error:
Stack Trace:
[ArgumentNullException: Value cannot be null.
Parameter name: user]
EPiServer.Notification.Internal.
