You can try changing your CompanyName property as follows:
[DojoWidget(WidgetType="epi-cms/form/PageInfoPicker"), Required]
public PageInfo CompanyName { get; set; }
Hi David,
Thanks for the update. Now i am able to see content tree structure to select the page but i am facing another problem here.
My company pagetype content pages doesn't have any controller & view so while configuring the visior group i am not able to select the company content page(this is the message showing "This container is not visible on the website"). Is there any other configuration to enable the selection in this case.
Suresh B
Hi Suresh
Can you post a screenshot of the issue? Are your company pages defined as Episerver Container pages?
David
Hi David,
Company pages created with "PageType". Below is the screenshot. Here i am trying to select "Test Company" page but it was disabled.
Common thing noticed here is, Pages which doesn't have any controller/view are disabled.
Suresh B
Hi Team,
I have a requirement to implement Visitor groups based on logged in user company. I am going create custom visitor group criterion model class.
But here Companies are maintaining in content structure and i want to use it ContentReference propery while creating vistor groups but It is always showing textbox only. Below is the class which i have created.
[EPiServerDataStore(AutomaticallyRemapStore = true)]
public class CompanyCriterionSettings : CriterionModelBase
[Required]
[Display(Name = "Company name")]
public ContentReference CompanyName { get; set; }
/// <inheritdoc/>
public override ICriterionModel Copy()
return ShallowCopy();
Suresh B
