When i am getting records i got these errors by using RestApi and Code First Can you please some one help me
Error CS0103 The name 'query' does not exist in the current context.
Error CS0103 The name 'First' does not exist in the current context.
Error CS0103 The name 'query.First' does not exist in the current context.
Error CS0161 'PurchaseOrderService.GetAllProductstatusdetails()':
Error CS1519 Invalid token '(' in class, struct, or interface member declaration
Error CS1519 Invalid token 'return' in class, struct, or interface member declaration
Error CS1513 } expected
This is my Purchaseorderservices.cs page.
using QFT_POMS_SVC.Domain.POMS;
using System.Linq;
namespace QFT_POMS_SVC.Services.POMS
public class PurchaseOrderService : IPurchaseOrderService
ProductStatusEntities entities = new ProductStatusEntities();
private DBMapper _dbContext;
private Result _result;
private object query;
public PurchaseOrderService()
_dbContext = new DBMapper();
_result = new Result();
public IList<Distributor> GetAllDistributorsOp()
var query = from d in _dbContext.DistributorRepository select d;
return query.ToList();
public IList<PurchaseOrder> GetAllPOByDistributorIdOp(int DistributorId)
var query = from po in _dbContext.PurchaseOrderRepository
where po.DistributorId == DistributorId
select po;
public PurchaseOrder GetPODetailsOp(int PurchaseOrderId)
where po.Id == PurchaseOrderId
select po;
return query.First();
private void UpdatePurchaseOrderItems(int purchaseorderid, List<PurchaseOrderItem> items)
foreach (var item in items)
var _item = _dbContext.PurchaseOrderItemsRepository.Where(po => po.Id == item.Id).First();
_item.QtyReceived = item.QtyReceived;
_item.Received = item.Received;
_item.UnitCostReceived = item.UnitCostReceived;
_item.Discontinued = item.Discontinued;
_dbContext.SaveChanges();
public Result UpdatePurchaseOrderOp(PurchaseOrder po)
var _purchaseOrder = GetPODetailsOp(po.Id);
_purchaseOrder.deleted = po.deleted;
_purchaseOrder.InvoiceDate = po.InvoiceDate;
_purchaseOrder.InvoiceDueDate = po.InvoiceDueDate;
_purchaseOrder.InvoiceNumber = po.InvoiceNumber;
//_purchaseOrder.items.Clear();
//_purchaseOrder.items = po.items;
_purchaseOrder.PORcvdAmount = po.PORcvdAmount;
UpdatePurchaseOrderItems(po.Id, po.items);
return _result;
public List<ProductStatusEntities> GetAllProductstatusdetails()
var query = from orditem in _dbContext.OrderItemRepository
from p in _dbContext.ProductRepository
from dpm in _dbContext.DistributorProductMappingRepository
from pwi in _dbContext.ProductWarehouseInventoryRepository
where
p.ProductTypeId == orditem.ProductId &&
dpm.ProductId == pwi.ProductId &&
dpm.ProductId == orditem.ProductId &&
orditem.Order.OrderStatusId == 20
group new { orditem, p, dpm.Distributor, dpm, pwi } by new
orditem.ProductId,
orditem.OrderId,
p.Name,
p.ProductTypeId,
Column1 = dpm.Distributor.Name,
dpm.StockStatus,
dpm.UnitPrice,
pwi.StockQuantity,
Column2 = p.StockQuantity
} into g
select new
g.Key.OrderId,
g.Key.ProductId,
productname = g.Key.Name,
g.Key.UnitPrice,
Distributorname = g.Key.Column1,
orderquantity = (int?)g.Sum(p => p.orditem.Quantity),
TotalQuantity = (int?)g.Sum(p => p.pwi.StockQuantity + p.dpm.StockStatus + p.p.StockQuantity); }
#204876
Edited, Jun 20, 2019 10:24
