Yep. Luc Gosso put together a blog post explaining how you can limit the available buttons in TinyMCE by user role. You can read it here:
https://devblog.gosso.se/2018/09/customize-tinymce-at-runtime-in-episerver-11/
Hi, it is also possible to use the TinyMCE configuration API: AddSettingsTransform.
For example you could add the "code" button (view HTML source) to the toolbar if the current user is in role "WebAdmins" like this:
config.Default().AddSettingsTransform("sample-add-code-button", (settings, content, propertyName) =>
var user = HttpContext.Current?.User;
if (user !=null && user.IsInRole("WebAdmins"))
settings.AddPlugin("code");
settings.AppendToolbar("| code");
Is it possible to configure TinyMCE editor to display options based on user roles?
