How to add category in page url?
I have a child page under start page as shown below. How to access child page with url "startpage/category/childpage." Normally we get url as "startpage/childpage" where category is property of PageData.
#204281
May 24, 2019 8:40
You can define a InitializableModule, inherit it from IInitializableHttpModule.
Then bind you event like:
public void InitializeHttpEvents(HttpApplication application)
       application.PreRequestHandlerExecute += this.ApplicationOnBeginRequest;
Now, inside your ApplicationOnBeginRequest method
private void ApplicationOnBeginRequest(object sender, EventArgs eventArgs)
     var contentRouteHelper = ServiceLocator.Current.GetInstance<IContentRouteHelper>();
     if (contentRouteHelper?.Content is PageData myPage)
          var cat = myPage.Category.First();
          var redirect = contentRouteHelper.Content.ParentLink + cat.ToString() + contentRouteHelper.ContentLink;
          HttpContext.Current.Response.Redirect(redirectUrl);
  1. Check if the request is for PageData type (as in above example)
  2. Get your category (I tried only first category).
  3. Format your url then redirect to it.
Note: This is high level idea only. Put proper null checks and exception handling.
Thanks & Regards
Praful Jangid
#204296
May 24, 2019 13:17
