Adding on-page editing to dynamically created elements issue
I am following a few blog posts I found that show how to add the data-epi-edit-name attribute to an element in order to enable on page editing. The problem I am running into is I have no control over the creation of the dynamically created element, so I have to add the attributes to it after the fact. It appears epi does not detect the change and does not refresh the OPE editor boxes. Even calling the epi.publish("beta/domUpdated") event on the client does not get it to be recognozed. I am at a loss, is there a way to get this to work?
#203819
May 07, 2019 23:49
Please check this article if it helps
https://world.episerver.com/documentation/developer-guides/CMS/editing/on-page-editing-with-client-side-rendering/
#203858
May 08, 2019 17:33
That was one I used to originally, but it does not work if I add the attributes after the page has finished loading. I am hoping someone else has ran into this.
#203861
May 08, 2019 21:59
Have you upgraded your solution?
#203879
May 09, 2019 11:19
