did you check what's actually happening on sql server level (like running trace)? when you enable "all" logging level - what's going on in log files? workaround to try would be to get all child pages and try to iterate over them and delete 1 by 1
As Valdis said, it would be interesting to try and delete either individually or in smaller batches and see how that works out.
Hello,
I am implenting a solution wherein we delete child pages from a container for the purpose of populating it with new pages from an import. There are ~500 pages under the container page. The code for this being:
_contentRepository.DeleteChildren(pressReleaseContainerPage, true, AccessLevel.NoAccess);This has been implemented elsewhere in the same solution with no issues (similar number of pages being deleted), however in this instance it is causing the following error in the stacktrace:
[Win32Exception (0x80004005): The wait operation timed out] [SqlException (0x80131904): Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding.] System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +212 System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +81 System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +631 System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4222 System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +58 System.Data.SqlClient.SqlDataReader.get_MetaData() +89 System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) +437 System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +2616 System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +1635 System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +64 System.Data.SqlClient.SqlCommand.ExecuteScalar() +268 EPiServer.DataAccess.Internal.<>c__DisplayClass15_1.<DeleteChildren>b__0() +218 EPiServer.Data.Providers.Internal.<>c__DisplayClass32_0.<ExecuteTransaction>b__0() +10 EPiServer.Data.Providers.Internal.<>c__DisplayClass33_0`1.<ExecuteTransaction>b__0() +55 EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +563 EPiServer.Data.Providers.Internal.SqlDatabaseExecutor.ExecuteTransaction(Func`1 action) +125 EPiServer.Data.Providers.Internal.SqlDatabaseExecutor.ExecuteTransaction(Action action) +90 EPiServer.DataAccess.Internal.ContentSaveDB.DeleteChildren(ContentReference contentLink, Boolean forceDelete) +194 EPiServer.Core.Internal.DefaultContentProviderDatabase.DeleteChildren(ContentReference contentLink, Boolean forceDelete) +33 EPiServer.Core.Internal.DefaultContentProvider.DeleteChildren(ContentReference contentReference, Boolean forceDelete) +18 EPiServer.Core.Internal.DefaultContentRepository.DeleteChildren(ContentReference contentLink, Boolean forceDelete, AccessLevel access) +1240 BordBia.Web.Plugins.Admin.PressReleaseImport.Controllers.PressReleaseImportController.Upload(HttpPostedFileBase file) in C:\projects\BordBia-Accelerator\source\Engage.EpiAcceleratorPack.Website\Plugins\Admin\PressReleaseImport\Controllers\PressReleaseImportController.cs:75 lambda_method(Closure , ControllerBase , Object[] ) +104 System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) +14 System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +157 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +27 System.Web.Mvc.Async.<>c.<BeginInvokeSynchronousActionMethod>b__9_0(IAsyncResult asyncResult, ActionInvocation innerInvokeState) +22 System.Web.Mvc.Async.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult) +29 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) +32 System.Web.Mvc.Async.AsyncInvocationWithFilters.<InvokeActionMethodFilterAsynchronouslyRecursive>b__11_0() +50 System.Web.Mvc.Async.<>c__DisplayClass11_1.<InvokeActionMethodFilterAsynchronouslyRecursive>b__2() +228 System.Web.Mvc.Async.<>c__DisplayClass11_1.<InvokeActionMethodFilterAsynchronouslyRecursive>b__2() +228 System.Web.Mvc.Async.<>c__DisplayClass7_0.<BeginInvokeActionMethodWithFilters>b__1(IAsyncResult asyncResult) +10 System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) +34 System.Web.Mvc.Async.<>c__DisplayClass3_6.<BeginInvokeAction>b__3() +35 System.Web.Mvc.Async.<>c__DisplayClass3_1.<BeginInvokeAction>b__5(IAsyncResult asyncResult) +100 System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +27 System.Web.Mvc.<>c.<BeginExecuteCore>b__152_1(IAsyncResult asyncResult, ExecuteCoreState innerState) +11 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +45 System.Web.Mvc.<>c.<BeginExecute>b__151_2(IAsyncResult asyncResult, Controller controller) +13 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +22 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26 System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10 System.Web.Mvc.<>c.<BeginProcessRequest>b__20_1(IAsyncResult asyncResult, ProcessRequestState innerState) +28 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28 System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +576 System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +132 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +163What could be causing this issue?
Much appreciated.
