Creating blocks in blocks not working with latest version
Since some time after version 11.10.6 the following features stopped working:
  • Creating a new block under a newly created block
    • That is, "For this block" -> "New block"
  • Creating a new block in a ContentArea inside a block
    • That is, using the "create a new block" button at the bottom of the ContentArea
How to reproduce for local blocks:
  • Create two Alloy sites, one with version 11.10.6 and one with latest version (as of this writing 11.11.3)
  • Create a new editorial block on some page on both Alloy sites
  • Select the newly created block for editing
  • Go to "for this block" on the right hand pane
  • Click "New Block"
At this stage, the 11.10.6 version shows all available block types while the latest version shows an empty list.
How to reproduce for ContentAreas:
  • Add a ContentArea to the EditorialBlock on both sites
  • Select an Editorial Block for editing
  • Click "create a new block" on the ContentArea
In both cases above, the CMS attempts to get all available content types using the following endpoint: /EPiServer/cms/Stores/contenttype/?query=getavailablecontenttypes
The 11.10.6 version includes the parameter &localAsset=true while the latest version does not. Calling the endpoint directly with the missing parameter returns the correct result in the latest version.
Is this a known bug? Is there a fix scheduled? Does anyone know of a workaround?
#203347
Apr 17, 2019 10:27
If that is the bug described, the fix is contained in version 11.19.2 and higher.
#203359
Apr 17, 2019 17:53
