Change the default language
I have a multi-site setup and need to change the default language on one of the sites.
Is there a straight forward way to do this in Episerver, without effecting the other sites' configuration?
#203011
Apr 06, 2019 5:48
Ravindra S. Rathore
Yes, You can do it using the manage website section in the admin panel.
This is set in admin mode > Config > Manage Websites > [select site] > Hit edit button
From the dropdown list pick the culture. This will set the default mapping for the domain
Ravindra
#203013
Apr 06, 2019 7:15
it depends either you need to change language detected by incoming request/host or you need to change language for content (aka master language).
#203263
Apr 14, 2019 14:59
