ok, more complications to this... given the option to edit source code, TinyMCE anutomatically removes empty span tags, so editing the source only works if I add the span with the class, an empty span instantly removed :-(
Hi Noel,
To allow users to wrap text in a span tag with a specific class, you should be able to set that up as a custom style either within the editor stylesheet (for the older version of tinyMCE) or programmatically (in tinyMCE 2). That said, for this kind of scenario I'd usually use JavaScript to add the "more" link, particularly if it's only used to trigger a JavaScript function.
Hi Paul, I've already explorer TinyMCE and it's config, cant find anything to allow what you are saying, hence this forum post. Can you show me some code?
This is a new build so it's using the lastest version of TinyMCE.
For TinyMCE 1 you can add something like the following to the editor css file:
span.more-button {
EditMenuTitle: Buttons;
EditMenuName: More button;
ChangeElementType: true;
background: #f00;
For TinyMCE 2 you need to configure custom styles in an IConfigurableModule:
[ModuleDependency(typeof(TinyMceInitialization))]
public class CustomizedTinyMceInitialization : IConfigurableModule
context.Services.Configure<TinyMceConfiguration>(config =>
config.For<StandardPage>(t => t.MainBody)
.Toolbar("styleselect")
.StyleFormats(
new { title = "More button", inline = "span", styles = new { background = "#f00" }, classes = "more-button" }
I have a requirement to allow editors to insert a "More" link inside an accordion (to encourage users to open the accordion), but my problem is the client's branding/css requires the "More" to be inside a <span>, which should itself be inside the last <p> tag (or whatever tag is the last block in the text).
So I'd like the editor to be able to insert their own <span> tag just as they can insert an <a> tag or similar, i.e. highlight the text and hit a button. From there I can add a custom style they can apply to the <span> tag to accomplish the "More" requirement.
I've also considered adding the "More" in code, but it's a difficult task trying to figure out which is the last paragraph or element in the XhtmlString.
