oEmbedMetaEditor.js not found in Multisite
we are running a multisite. Latest epi 10.
With one of the sites, when i try to edit a block, i get oEmbedMetaEditor.js could not be loaded and the whole UI craches.
When i look at the path from where epi tries to load the the oEmbedMetaEditor.js i see that something is dodgy.
The oEmbedMetaEditor exists in modules/_protected/ {geta-epi-cms\Geta-EPi-Cms.zip\1.1.6.0\ClientResources\Scripts\editors}
The zip file containes, there is a module.config file that looks like this:
<module productName="Geta EPi Cms UI" clientResourceRelativePath="1.1.6.0" loadFromBin="false">
<assemblies>
<add assembly="Geta.EPi.Cms.UI" />
</assemblies>
<dojo>
<paths>
<add name="geta-epi-cms" path="ClientResources/Scripts" />
</paths>
</dojo>
<clientModule initializer="geta-epi-cms/CommandsInitializer">
<moduleDependencies>
<add dependency="CMS" type="RunAfter" />
</moduleDependencies>
</clientModule>
</module>
Error: "scriptError"
  • _f2Dojo
dojo.js:15:19769
  • <anonym>5Dojo
_f@http://localhost:58323/cms/Shell/10.10.6.0/ClientResources/dojo/dojo.js:15:436 req.injectUrl/_10c<@http://localhost:58323/cms/Shell/10.10.6.0/ClientResources/dojo/dojo.js:15:17745 widgets.js:2:220692
    • _5f2 http://localhost:58323/cms/Shell/10.10.6.0/ClientResources/epi/shell/widgets.js:2
  • signal4Dojo
  • signal
  • _9
  • signal
  • _10c
Loading failed for <script> with source “http://localhost:58323/cms/Shell/10.10.6.0/ClientResources/adventure/editors/oEmbedMetaEditor.js”.
??So why and where does EPi or .net gets the adventure added (site name is adventure)?
Is there something that was missed in the web.config, some setting?
#202161
Edited, Mar 18, 2019 9:50
