I know that for some certain routes you have to specify default.aspx as content output
For instance /EPiServer/cms/admin/ does not return the admin view but /EPiServer/cms/admin/default.aspx does.
This should however not be part of your problem...
Nada in Console.
Nada in log file.
/default.aspx makes it throw 404 "A public action method 'default.aspx' was not found on controller 'EPiServer.Cms.Shell.UI.Controllers.Internal.VisitorGroupsController'."
/index = empty blank
Something is killling it softly, it probably something stupido.
How does your <episerver.shell> and <location path="EPiServer"> configuration look like in Web.config?
Full access no diff.
I have same behavior on staging server, so its not just local.
Have i Messed up SiteViewEngine : RazorViewEngine? i don't find anything there too though
The RouteTable looks as good as you do Jedi Master Iljuconoks.
39 items.
you have items like
{[ModuleRouteCollection RoutePath="~/EPiServer/EPiServer.GoogleAnalytics/2.1.1", Routes=[EPiServer.GoogleAnalyticsepi-googleanalytics]]}
{[ModuleRouteCollection RoutePath="~/EPiServer/EPiServer.DeveloperTools", Routes=[]]}'
{[ModuleRouteCollection RoutePath="~/episerver", Routes=[EPiServer.Packaging.UI,EPiServer.Search.Cms,AddOn.Edit.ContextMenuOpenInNewTab,EPiServer.DeveloperTools,Shell,CMS,EPiServer.Cms.TinyMce,EPiServer.Forms.UI,EPiServer.Forms,EPiServer.GoogleAnalytics]]}
What more should i be looking for?
If you reach out for developer support service for this, I would be happy to look into this :)
Cred to Episerver Dev Support,
After debugging Episerver Source they found out the root cause of this issue is SiteViewEngine is inserted to ViewEngines in the first position:
ViewEngines.Engines.Insert(0, new SiteViewEngine()); // which is default in alloy template to optimize view resolving when using DisplayFor/PropertyFor
So it overrides the episerver ViewEngine.
You can use this instead of:
ViewEngines.Engines.Add(new SiteViewEngine());
We did made some customization in viewengine so maybe not so suprising.
Regards
Hey I deserve a bit of credit as well ;) (telling you to reach out for Dev support)
To tweak view resolving a little bit, you could insert it right before WebFormViewEngine (if using default MVC setup):
var webFormViewEngine = ViewEngines.Engines.FirstOrDefault(ve => ve.GetType() == typeof(WebFormViewEngine));
if (webFormViewEngine != null)
var webFormViewEngineIndex = ViewEngines.Engines.IndexOf(webFormViewEngine);
ViewEngines.Engines.Insert(webFormViewEngineIndex, new SiteViewEngine());
else
Hello Experts,
Latest version 11.12 CMS
I´ve set up a new site but no modules routes are working.
not /EPiServer/Cms/VisitorGroups
not /EPiServer/EPiServer.DeveloperTools/IOC
not /EPiServer/EPiServer.GoogleAnalytics/Administration
Just blank no html output
I do get to login before though
What can it be?
I do use feature folder setup, but thats just a simple change in DefaultPageController.
