There might be a problem with your database, because netProjectItemDelete should have been created in 7.10.0.sql. You can run this manually to create it
PRINT N'Creating [dbo].[netProjectItemDelete]...';
GO
CREATE PROCEDURE [dbo].[netProjectItemDelete]
@ProjectItemIDs dbo.IDTable READONLY
AS
BEGIN
SET NOCOUNT ON
MERGE tblProjectItem AS Target
USING @ProjectItemIDs AS Source
ON (Target.pkID = Source.ID)
WHEN MATCHED THEN
DELETE
OUTPUT DELETED.pkID, DELETED.fkProjectID, DELETED.ContentLinkID, DELETED.ContentLinkWorkID, DELETED.ContentLinkProvider, DELETED.Language, DELETED.Category;
END
GO
11.2.0.sql will update it anyway so you don't have to worry about correctness
Hi Quan!
Thank you so much for your feedback!
I will try it out and give you feedback when I know how it goes!
I am most greatfull, thanks!
Kind regards,
Jon Haakon
I'm doing an upgrade on Episerver CMS version 10.3.2.
When I run Update-EPiDatabase in "Package Manager Console" all packages from 7.8.0.sql to 11.0.0.sql runs however when
11.2.0.sql is beeing processed epideploy.exe breaks with the error:
EPiDeploy was stopped due to an exception, more details:
System.Data.SqlClient.SqlException (0x80131904): Invalid object name 'dbo.netProjectItemDelete'.
at System.Data.SqlClient.Td
sParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at EPiDeploy.Sql.ScriptRunner.<>c__DisplayClass5.<ExecuteScript>b__3()
at EPiDeploy.Sql.DatabaseHandler.Execute[T](Func`1 f, Boolean commit)
at EPiDeploy.Sql.ScriptRunner.ExecuteScript(StreamReader stream)
at EPiDeploy.Sql.ScriptRunner.ExecuteScripts(IEnumerable`1 files, Boolean requiresValidation)
at EPiDeploy.Sql.ScriptRunner.<>c__DisplayClass1.<Execute>b__0()
at EPiDeploy.Common.Executor.Execute(ILocation location)
at EPiDeploy.Deploy.Execute(Options options, ILocation startPosition)
at EPiDeploy.Deploy.Run(Options options)
at EPiDeploy.Program.Main(String[] args)
ClientConnectionId:59b1bd10-70dd-4337-b43f-d70206bae42e
Error Number:208,State:6,Class:16
How come dbo.netProjectItemDelete is missing?
How do I fix this?
In advance thanks for your help!
Kind regards,
Jon Haakon Ariansen
