Nested Blocks keep disappearing!!
I have a very strange phenomenon whereby when i add blocks to content areas in other blocks, a few minutes later they disappear. I thought i was going mad, but its reliably repeatable. I have never encountered this before and have no idea what could be happening? I even copied the database down to my local machine but that made no difference. Does anyone have an idea what might be happening?
#201540
Feb 22, 2019 10:14
Hi what version of Episerver are you running? I do remember a bug a couple of months back in the UI that would exhibit similar behaviour and updating to the latest and a hard refresh solved it.
#201547
Feb 22, 2019 11:14
11.9
#201551
Feb 22, 2019 11:19
I thought it was a websockets issue, but the problem is still there.
#201557
Edited, Feb 22, 2019 11:31
Assume this is production? Are you using load balancing? Are the remote events configured correctly if so?
#201566
Feb 22, 2019 13:02
Hi David,
No, it is not happening on Production, only on my dev environment. When i posted the error I thought that I was using ContentAreas, but its actually  IList<ContentReference>.
I am getting JSON errors in the logs, so i think its a problem with using IList<ContentReference>, and changes to EPi regarding the use of JSON in storing these types.
[AllowedTypes(typeof(ContactItemBlock))]
public virtual IList<ContentReference> Contacts { get; set; }
I have now decorated the lists with [JsonProperty], and they are not disappearing now - but all the references are gone, so I will have to put in all the data again when i deploy to production.
#201571
Edited, Feb 22, 2019 13:46
Feb 22, 2019 14:10
Hi Dejan,
Looks like that is the way to go!
Marshall
#201582
Edited, Feb 22, 2019 14:22
