Expired content not moving to selected archive folder
Episerver v11.12.0 hosted at Episerver Azure
I have marked several pieces of content to expire at a certain time.  Episerver gives the editor the option to Archive the content to a different folder.  However, the content gets marked as Expired but does NOT move to the designated archive location.  What prevents this?  Or is it a bug?
#211269
Edited, Dec 24, 2019 17:46
Ravindra S. Rathore
Hi Eric,
First of all please check the logs, you will definitely find something there.
And please make sure that content author must have the access to archieve folder because permission might be issue here.
#211272
Dec 24, 2019 19:29
The editor was a member of the Administrators group.  The archive folder location has the same permissions as the originating folder.  So don't think permissions are an issue.
Also, not a single line in the application logs that an error occurred.
#211273
Dec 24, 2019 21:16
Ravindra S. Rathore
Hi Eric,
Is your Archive Function Scheduled Job is active?
Try to run it manually and then check.
#211276
Dec 25, 2019 5:06
Thanks, Ravindra.  I did not realize this was a separate job that needed to be enabled.  I would think it would run "out of the box"
#214662
Jan 10, 2020 14:18
Ravindra S. Rathore
#215748
Edited, Jan 13, 2020 4:53
