Update page programatically without triggering ContentEvents
Tomas Hensrud Gulla
Tomas Hensrud Gulla
OMVPworkspace_premiumPaaS CMS Developer Certificationworkspace_premiumSaaS CMS Developer CertificationSaaS CMS Administrator CertificationOpal Administrator CertificationDXP Administrator Certificationworkspace_premium
I have a pagetype with some code in the event contentEvents.PublishedContent. Is it possible to update a page of this type without triggering the event. When editors update the page, I still want the event to be triggered.
I can use SaveAction.SkipValidation to skip validation, but is there a way to skip content events?
#210603
Nov 29, 2019 13:25
There is no way to supress the events that I know of, but you can probably tackle the problem from a different perspective, like you can convert the IContent in PublishedContent event to, IChangeTrackable, and check if ChangedBy is something that assigned specifically for code or not before processing.
#210606
Nov 29, 2019 14:13
Tomas Hensrud Gulla
Thank you Quan.
I ended up checking if SaveContentEventArgs.ForceCurrentVersion was true. For my use case, ForceCurrentVersion is set when I change this specific page from code.
#210607
Nov 29, 2019 14:23
Tomas Hensrud Gulla
Quan: I'm not sure if I understood you correctly. In my use case, Changed By will be the username of the logged-in user using the admin tool that updates the pages programmatically. Because of the need for tracability, I can not change this to a pseudo-username like «update-by-code-user».
Is there some other property I can set during save, that I can check in ContentEvents. I do not actually want to ForceCurrentVersion, but instead create a new version of the content.
#210722
Dec 04, 2019 10:48
In the PublishedContent event, you can look at the "SaveContentEventArgs.Transition".
For programmatic publishing it should be "Published -> Published", and for manual publishing it should be "CheckedOut -> Published"
#210741
Dec 04, 2019 12:28
- Dec 05, 2019 10:16
Thanks! :-)
