The default Find "search provider base" uses HttpUtility.HtmlEncode for name which results in the strange thing you see. We will see if we can lift that restriction, but I'm not quite sure it will be prioritized
Hi, I am facing this issue
On both sides I searched for "d". When I check response for the network call for left search I can see title has numeric character reference for letter ø, while previewText is Ok.
In assets pane response has only name which has correct value
Does anyone have any idea how to deal with this. Is this matter of indexing, or UI bug? Both sides use same search source, do I expect that correctly?
