CMS - Azure Storage for Assets files
I have searched documentation but cant find any example and wonder.
1) Is it possible to use Azure Storage (Blob or File) to store assets files like pdf, docx  i.e files that editor could upload and reference?
If its possible:
1.1) Is it possible to structure uploaded files in "catalogues" in Epi edit mode. As I know Blob storage in Azure is kind of a flat structure but maybe you could use Container as a catalogue or?
1.2) Is it possible to use ACLs for files so you can filter files based on logged in user/editor?
Thanks!
#210593
Edited, Nov 28, 2019 19:20
Ravindra S. Rathore
Hi Coder,
Answer for you first question is yes you can upload the blobs in Azure storage
https://world.episerver.com/blogs/ram-kumar-k/dates/2018/3/using-azure-cloud-for-storing-episerver-cms-blobs/
but for other questions I think out-of-the-box is not available.
#210595
Nov 28, 2019 20:08
1. Yes, you can just install EPiServer.Azure, configure Azure blob storage and everything will be transparent to the editors. (Actually if you are using the disk-based blob provider the physical folder structure is quite "flat" as well. the logical structure is "abstracted"
2.Yes, ACL can be set to media
#210598
Nov 28, 2019 22:03
