Set Default Value based on other property
Hello,
In my page type, I have two fields Theme and Branding
I want to set value of Branding based on Theme on Content Creation.
I am trying to do this in SetDefaultValues method but it's not working
Any suggestions?
#208066
Oct 11, 2019 17:36
Edited, Oct 11, 2019 20:00
JayeshM - Oct 14, 2019 17:20
Thanks, Ravindra .it worked. However now i need to delete the Theme property from Edit UI, how can I achieve that?
- Oct 14, 2019 19:42
You can hide it for Editors by using
[Ignore]
public int HiddenPrimaryKey { get; set; }
[Display(Name="Readonly Property")]
[Editable(false)]
public virtual string ReadonlyProperty {get;set; }
http://www.jondjones.com/learn-episerver-cms/episerver-developers-guide/episerver-properties/how-to-hide-a-property-in-episerver-cms-and-how-to-make-a-property-readonly
http://joelabrahamsson.com/hiding-episerver-properties-from-editors
https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2016/9/hiding-a-property-using-scaffoldcolumn/
Hey @Jayesh
Here is a commonly referenced blog that demonstrates dependent drop-down lists.
https://world.episerver.com/blogs/Duong-Nguyen/Dates/2014/1/Country-Region-drop-down-lists-in-All-properties-mode/
Its important to note that newer versions of Episerver have changed things a bit, so please make sure you read the newer Comments in that Blog post, and refer to this Forum post.
https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2017/4/linked-dropdown-does-not-display-value/
Hope this helps.
#208091
Oct 13, 2019 1:00
