SelectionFactory set Initial/Default value and display it's placeholder in select/dropdown box
Hi all,
I found this topic here - https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2014/9/Setting-a-ISelectItem-as-selected/ - but none of the solutions solves my problem.
I have this property on a page, which uses custom Selection Factory.
And I want to set initial value and display it's placeholder (in admin view, under "All properties" view while creating new page) here in a select box. I do it like this:
// CustomSelectionFactory.cs:
public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
    List<SelectItem> result = new List<SelectItem>()
        new SelectItem() { Text = "All", Value = null }
    List<CustomSelectItem> customSelectItems = new List<CustomSelectItem>();
    switch (metadata.PropertyName)
        case "DocumentCountry":
            customSelectItems = Api.GetCustomSelectItems(1).Result;
            break;
        case "DocumentLanguage":
            customSelectItems = Api.GetCustomSelectItems(2).Result;
            result.RemoveAll(x => x.Text == "All");
            metadata.InitialValue = "1";
            break;
    foreach (CustomSelectItems customSelectItem in customSelectItems)
        result.Add(new SelectItem()
            Text = customSelectItem .Name,
            Value = customSelectItem .Id.ToString()
    return result;
// CustomPage.cs
[Display(Name = "Document Country")]
[SelectOne(SelectionFactoryType = typeof(CustomSelectionFactory))]
public virtual string DocumentCountry { get; set; }
[Display(Name = "Document Language")]
public virtual string DocumentLanguage { get; set; }
Help appreciated!
#208399
Edited, Oct 23, 2019 11:20
Ravindra S. Rathore
You can set the default value.
    //Set values here
#208402
Oct 23, 2019 12:15
fuji - Oct 23, 2019 13:50
Ok, now this worked (even without setting "metadata.InitialValue = "1";" in "CustomSelectionFactory.cs", the issue was probably because "DocumentLanguage" property was of type "int?". Thank you!
@Ravindra S. Rathore,
I think I have tried it and it partly works - on publish it passes further the default value, but the placeholder of selectbox is still empty
#208403
Oct 23, 2019 12:17
Ravindra S. Rathore
Placeholder in CMS or on the front-end site?
#208405
Oct 23, 2019 12:31
fuji - Oct 23, 2019 12:42
In admin view, under "All properties" view while creating new page, so I guess it's CMS? :D
