Prevent hijacking Ctrl + Tab keyboard shortcut
Hi, everyone!
Is it possible to prevent Episerver CMS from hijacking the Ctrl + Tab keyboard shortcut when editing a page in all properties mode? How might I do that?
I'm working with Episerver CMS 11.13.1 with UI version 11.21.7.
Edit: The shortcut is also hijacked in OPE, and probably elsewhere.
#207854
Edited, Oct 07, 2019 10:39
Ravindra S. Rathore
I am using the same version(see screenshot below) and I am able to switch the tabs using Ctrl+Tab button in chrome.
Which browser and browser version you are using?
#207891
Oct 08, 2019 6:54
Thanks for looking into my issue.
You're completely right, it seems to be a browser issue. I'm using Vivaldi, which, seems to be the only browser with this problem. Since I'd never experienced this before, I sort of jumped the gun a little bit and thought it was an Episerver "convenience".
What happens is that Ctrl + Tab cycles the tabs in all properties mode when editing a page. If the left or right navigation pane is in focus, Ctrl + Tab will cycle the tabs there too. It does not cycle the tabs shown in Admin -> Config -> Plug-in Manager (shown above).
So it seems to be connected with the ARIA tab role property of the offending tabs. In any case, I'll look into whether there is a way of disabling this in Vivaldi.
#207898
Oct 08, 2019 10:55
