Is there a reason why you want to run this on a VM in Azure? I would prefer using Web Apps as you don't have to worry anymore about the maintainance of a VM.
That would be most appropriate for a new installation but in my scenario, I have to migrate from a bespoke environment currently running on physical servers in a private data centre to the public cloud. It is - unfortunately - necessary to use IaaS due to time constraints. As is the norm, the cost of the environment is of particular importance and the B-Series is more cost-effective in the long-term. I have - however - no experience on running Episerver on the B-Series and was hoping someone on the forum has.
That makes sense. I have no experience with the B-Series VM's so nothing to say about that. Based on the spec sheets, I think it is also depending on the current load of your machine to see if it is worth while to use.
Good Morning
I would like to know whether anyone on the forum has experience on installing Episerver CMS (version 11.10.1) specifically on Microsoft Azure B-Series (https://azure.microsoft.com/en-gb/blog/introducing-b-series-our-new-burstable-vm-size/) Virtual Machines? The environment would be load-balanced using an Application Gateway (Layer 7), Azure SQL database and blobs being stored in Storage Accounts.
If you have attempted this, have you experienced any adverse effects -or- would you actually recommend it?
George
