Password validator in aspnet identity
We are developing a new Episerver site with aspnet identity. I managed to configure the passwordvalidator like this:
public class ApplicationBuilderExtensions
        public static ApplicationUserManager<TUser> CustomApplicationUserManager<TUser>(IdentityFactoryOptions<ApplicationUserManager<TUser>> options, IOwinContext context) where TUser : IdentityUser, IUIUser, new()
            var manager = new ApplicationUserManager<TUser>(new UserStore<TUser>(context.Get<ApplicationDbContext<TUser>>()));
            manager.PasswordValidator = new PasswordValidator
                RequiredLength = 6,
                RequireNonLetterOrDigit = false,
                RequireDigit = false,
                RequireLowercase = false,
                RequireUppercase = false
Now I'm wondering how to access this password validator, when validating a password in a controller?
I tried this:
var passwordValidator = ServiceLocator.Current.GetInstance<PasswordValidator>();
but it isn't populated with the values I set up in the ApplicationBuilderExtensions.
#208341
Oct 22, 2019 12:18
you should not try to inject the password validator, instead you should use ApplicationUserManager.PasswordValidator where the ApplicationUserManager can be injected of course.
#208357
Oct 22, 2019 14:02
pretty much untested, but this probably works (adding to ConfigureContainer method of one of your IConfigurableModule)
var services = context.Services;
  services.AddSingleton<PasswordValidator>((locator) => new PasswordValidator
RequiredLength = 6,
Then you can add PasswordValidator into your controller via constructor injection (you would need to register a DependencyResolver if you haven't already)
#208358
Oct 22, 2019 14:42
