DXC Deployments - Json Transfoms
In DXC we can use Web.config transforms to modify our web.configs for different environments e.g. production.
My current project has json files which need transforms applied for various environments. Azure deploments also supports json config\transforms via JSON variable substitution as in link below.
https://docs.microsoft.com/en-us/azure/devops/pipelines/tasks/transforms-variable-substitution?view=azure-devops#json-variable-substitution
Is it posible to perform\configure JSON variable substitution for DXC deployments and if not what is the wrokaround?
#207716
Oct 01, 2019 10:18
Ravindra S. Rathore
Hi Brendan,
As you are using the DXC Services so I think you should contact Episerver support about this because the JSON transform may or may not be supported by DXC Services.
Ravindra
#207771
Oct 02, 2019 14:33
