Custom Link Editor supported?
Hello,
our customer wants the possibility to add a new property "Event-Category" to a link which we can use when the link is rendered.
Does the Link-Editor Dialog support custom elements?
#207871
Edited, Oct 07, 2019 16:56
Tomas Hensrud Gulla
You may use the field «Remaining URL» to add URL-parameters like ?eventcategory=4.
#207879
Oct 07, 2019 21:25
Praful Jangid
I would also recommend the use of Remaining URL field. That will save your efforts.
In addition to suggetion by @Thomas you can also use it like ?category=yourcategoryname1&category=yourcategoryname2 for same category or for multiple categories ?category1=yourcategoryname1&category1=yourcategoryname2&category2=yourcategoryname1&category2=yourcategoryname2
#207961
Oct 09, 2019 13:17
Thanks Tomas and Praful,
i have verified that this approach works, i like it. Just i'm still waiting for the ok of the customer. Maybe he finds this approach too complicated for the cms editors, they need to know that the Event-Category information must be appended as Url Parameter. So i've hoped for an easier way to customize the link-editor. I guess you can do it with a dojo widget, can't you? I'm just not very familiar with it and have hoped that someone could show this approach.
Another way would be to add the property to a custom Block we already have(Link-Block). Then i needed to support drag&drop on the TinyMCE editor, so implement javascript logic to add the custom data-attribute when the editor drops the block. This must be done also at serverside when the link is not dropped onto the editor but added to a content area. This is very complicated and prone to errors(regex and HTML can be a nightmare).
So i see that your way with using the "Remaining Url" is pretty straightforward and also easy to extend.
#207962
Edited, Oct 09, 2019 13:28
- Oct 09, 2019 13:44
Definitely, there are other possibilities to do that. If your client what customization then let's do that. Happy to help.
