Recently Episerver changed it's CMS user interface so it might be because of that.
Can you please try the same scenario with new Episerver installation(same version you mentioned above) and if you see the same behavior there then you can ask Episerver support about this.
It seems like you have already existing CSS override in your solution.
Do a global search with the IDs in your solution (search with ctrl+shif+f in VS to find #epi-applicationBodySidebar and #epi-applicationBodyMain).
After upgrade, edit mode community interface does not rendered fully
Recently we have upgraded our episerver to the following versions,
After upgrade edit mode community interface appear to be cutoff, (overflow hidden) and only a small part of the content is visible. After inspecting this apear to be causing form a dynamic height which is added to the #epi-applicationBodySidebar and #epi-applicationBodyMain elements, for each of this elements with this id, there is a dynamic height of 68px being added, which result in screens with only 68px of content visible.
What is the solution which we can use to resolve this issue?
