After publishing page, blocks not preview in edit view
In EPI Server CMS, I have managed the content area through the cascading feature (which is custom). If the user edits the top-level page and placed the blocks on the top page then it automatically inherited up-to child-level using cascade features and we can see the change in edit preview mode before to publish, but once page published and then add/remove the block from page then it does not show in edit preview mode, however after re-publishing the page I can see the changes.
Any idea why preview mode not working after publishing the page for blocks?
#208058
Oct 11, 2019 15:04
Tomas Hensrud Gulla
Ravindra S. Rathore
You can create a Preview block using the Templatedescriptor or you can go with Tomas's suggestion.
#208071
Oct 11, 2019 20:04
Sanjay Kumar - Oct 14, 2019 8:58
Hey, @Ravindra- I have already created a Preview block using the Templatedescriptor feature but the problem still exists.
Praful Jangid
Hi Sanjay,
When you do changes then auto save feature is working, right? If you are getting any exception in logs or console (js related), please share here for more context about the issue.
#208093
Oct 14, 2019 5:19
Hi @Praful,
Yes, it's related to the autosave feature.
Actually the problem is that when we created a new page and added blocks on the page and see changes in preview mode which looks good, but after publishing the page and added new blocks again then it does not appear in preview mode. I have checked the logs for that issue but not found.
#208128
Edited, Oct 14, 2019 17:29
