Have you tried that with adding ClientResources script file? That may help in bringing back Globe icon. :)
I managed to bring the globe back, but the link href does not get updated when I select another page from the page tree. Clicking the globe always open the start page...until I refresh the page.
So, in that case we will need to find a way to bind js event that will update url. Let's do more research than 😎
I managed to get something working. Now I've got this button, that opens the page in a new browser tab.
https://imgshare.io/image/globe.vevKl
I got some inspiration from this: https://world.episerver.com/documentation/developer-guides/CMS/user-interface/command-pattern/Plugging-in-commands/
I still get the URL from the «Options --> view on website»-link. A little hackish.
//alloy/ViewOnWebsiteCommand.js
define([
"dojo/_base/declare",
"epi/shell/command/_Command"
function (declare, _Command) {
return declare([_Command],
iconClass: "epi-iconWebsite",
canExecute: true,
_execute: function () {
var url = document.querySelectorAll('[data-dojo-attach-point="lastPublishedViewLinkNode"]')[0].href;
window.open(url);
Then add a button to the global toolbar:
//alloy/CustomToolbarProvider
define([
"dijit/form/Button",
"epi-cms/component/command/_GlobalToolbarCommandProvider",
"alloy/ViewOnWebsiteCommand"
function (declare, Button, _GlobalToolbarCommandProvider, ViewOnWebsiteCommand) {
return declare([_GlobalToolbarCommandProvider],
constructor: function () {
this.inherited(arguments);
this.addToTrailing(new ViewOnWebsiteCommand(
{ label: "View on website" }),
{ showLabel: true, widget: Button });
And kick it all off in an initializer:
//alloy/Initializer.js
define([
'dojo/_base/declare',
"epi/dependency",
"alloy/CustomToolbarProvider"
], function (declare, dependency, CustomToolbarProvider) {
return declare(null, {
initialize: function () {
var commandregistry = dependency.resolve("epi.globalcommandregistry");
//The first parameter is the "area" that your provider should add commands to
//For the global toolbar the area is "epi.cms.globalToolbar"
commandregistry.registerProvider("epi.cms.globalToolbar", new CustomToolbarProvider());
And the initializer, is of courde referenced in module.config:
<clientModule initializer="alloy.Initializer">
<moduleDependencies>
<add dependency="CMS" type="RunAfter" />
</moduleDependencies>
</clientModule>
<dojo>
<paths>
<add name="alloy" path="Scripts" />
</paths>
</dojo>
It kinda works, but I'm not 100% satisfied. I would prefer:
- A link (<a href) that can be clicked, right-clicked. Makes it possible to open in the same tab, open in other tab, open in other window etc.
- Getting the url of the current page in some way better
- Disabling the button when no URL is available (container page, page not created in current language etc)
Any suggestions for improvements...?
I guess I should hook into the event that fires when a node in the PageNavigationTree is clicked. I'm not sure how to do that, though.
I found this: https://world.episerver.com/documentation/developer-guides/CMS/user-interface/Context-sensitive-components/
And changed the Initializer to this, in order to subscribe to the ContextChangeEvent, and I get an alert with the correct URL when I click a node in the page tree.
define([
"epi/dependency",
"alloy/CustomToolbarProvider",
"dojo/topic"
], function (declare, dependency, CustomToolbarProvider, topic) {
topic.subscribe("/epi/shell/context/changed", this._contextChanged);
_contextChanged: function (newContext) {
if (!newContext) {
return;
alert(newContext.publicUrl);
I'm not really sure how to update the link target on my toolbar button...
I can move the subscription to the command. To be able to have a functional link before the first event is triggered (on page load, before first click in page tree), I get the current context in the constructor.
define([
"epi/shell/command/_Command",
"dojo/topic",
"epi/dependency"
function (declare, _Command, topic, dependency) {
canExecute: true,
var contextService = dependency.resolve("epi.shell.ContextService");
var currentContext = contextService.currentContext;
viewOnWebsite = currentContext.publicUrl;
window.open(viewOnWebsite);
if (!newContext) {
return;
viewOnWebsite = newContext.publicUrl;
The variable viewOnWebsite (that contains the URL) is global now? How should I encapsulate that?
I got the globe-button added to the toolbar.
Short blog post, including a link to github repo, with full source code, and package up on nuget.org:
https://blog.novacare.no/put-the-globe-back-in-episerver/
If anyone could tell me how to be able to hide the globe, instead of change the icon, when publicUrl is null - I would greatly appreciate it!
(I'm having a hard time trying to understand all that dojo stuff)
I would really like to get the globe back, to be able to «view on website» with one single click.
I guess it should be possible to add a button like this, getting the url from the link «view on website».
Example: https://imgshare.io/image/globe.vA9aq
If I were able to call the following javascript when the UI is fully loaded, it would work. Running the javascript from the browser's console puts the globe back in place.
Any suggestions?
