TinyMCE 2 Prevent Code Rewirtes
I'm having a probelem with the TinyMCE editor rewriting code when I go to the code view, and it is breaking things.
For example I'm trying to add a span tag inside an a tag for a font awesome icon.
I have this
<a class="btn btn-primary"><span class="fa fa-search">&nbsp;</span></a>
But when I add an ID to the a class it rewrites the HTML to this
<a id="test" class="btn btn-primary"></a><span class="fa fa-search">&nbsp;</span>
There is absolutly no reason for it to re-write this code.  So I need a way to prevent TinyMCE to prevent code rewrites
The ony thing I have discoved in the TinyMCE documentation was a "Verify HTML" for version 3.  But since EPi now uses version 4, this seems to no longer work.  I've added these settings in my TinyMCE config, and I can't get it to stop rewriting html from the code view.
.AddSetting("verify_html ", "false")
.AddSetting("cleanup", "false")
Any Suggestions?
#200402
Jan 10, 2019 20:14
Hi Valina,
As far as I can see cleanup would have done the trick, but was removed in 3.4.
However, checkout allow_html_in_named_anchor, seems like it will do exactly what you want!
#200436
Jan 11, 2019 16:53
Hi Jake,
Thanks for the suggestion, but i can't seem to get this, nor any of the settings to work.
I've added the .AddSettings throughout the  config and I can't seems to get this, or the keep_styles = false to apply
Here is what I have, and for some reason the "addSettings" are not applying.
 config.Default()
                .AddEpiserverSupport()
                .ContentCss("/static/css/Editor.min.css")
                .AddPlugin("lists epi-link image charmap print preview anchor  code searchreplace  fullscreen  media table help  epi-image-editor  epi-dnd-processor epi-personalized-content spellchecker")
                .Toolbar("formatselect styleselect removeformat | bold italic charmap | anchor epi-link  epi-dnd-processor epi-personalized-content  | image epi-image-editor media  | table  bullist numlist | searchreplace  | undo redo |  code ")
                .BlockFormats("Paragraph=p;Header 2=h2;Header 3=h3;Header 4=h4;Header 5=h5;Header 6=h6")
                .StyleFormats(
                    new { title = "Screen Reader text", inline = "span", classes = "sr-only" },
                    new { title = "Red", inline = "span", classes = "red" },
                    new { title = "Center", selector = "*", classes = "text-center" },
                    new { title = "Indent", selector = "*", classes = "indent" },
                    new { title = "Clear Fix", selector = "*", classes = "clearFix" }
                    .AddSetting("keep_styles", "false")
                    .AddSetting("allow_html_in_named_anchor ", "true")
                    .AddSetting("allow_conditional_comments", "true")
I've even trieds adding .AddSetting("selector", "textarea" above the keep_styles and nothing is working.
#200521
Jan 14, 2019 18:57
Somehow managed to delete both my posts. Anyway, I copied and pasted your configuration into Alloy and removed the extra space in allow_html_in_named_anchor:
...and it worked!
After checking what keep_styles does, I also think it worked although haven't tested thoroughly.
#200524
Jan 14, 2019 19:42
I took off the space and I was still having some funky problems.
I added valid_childen and that seemed to work.  It isn't the best soultion, but I think it might  be working for now...
.AddSetting("valid_children", "a[div|p|h1|h2|h3|h4|h5|h6|ul|ol|li|strong|em|i|img|span]")
#200525
Jan 14, 2019 20:30
rizwansegana - Apr 20, 2021 10:47
Hai Valina,
Where should i add this ?!, myself also having same issue.
Faisal - Apr 20, 2021 10:48
i need also
- Apr 20, 2021 10:52
Documentation:
https://world.episerver.com/documentation/developer-guides/CMS/add-ons/customizing-the-tinymce-editor-v2/configuration-api/
Example:
https://github.com/episerver/alloy-mvc-template/blob/master/src/Alloy.Mvc.Template/Business/Initialization/ExtendedTinyMceInitialization.cs
