However, this was working fine. But suddenly it has given an error. And it keeps happening forever. The exception throws from the RemoveUser(IUser user).
The exception details are here as below,
System.Data.SqlClient.SqlException (0x80131904): Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding. ---> System.ComponentModel.Win32Exception (0x80004005): The wait operation timed out
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at EPiServer.Community.Forum.Data.ForumFactory.<>c__DisplayClass33_0.<UserRemovedCleanUp>b__0()
at EPiServer.Data.Providers.Internal.SqlDatabaseExecutor.<>c__DisplayClass32_0.<ExecuteTransaction>b__0()
at EPiServer.Data.Providers.Internal.SqlDatabaseExecutor.<>c__DisplayClass33_0`1.<ExecuteTransaction>b__0()
at EPiServer.Community.Forum.ForumModule.DefaultSecurity_RemovedUser(ISecurityHandler sender, IRemoveUserEventArgs args)
at EPiServer.Common.Security.RemoveUserEventHandler.Invoke(ISecurityHandler sender, IRemoveUserEventArgs args)
at EPiServer.Common.Security.SecurityHandler.OnRemoveUser(IRemoveUserEventArgs args)
at EPiServer.Common.Security.Data.SecurityFactory.<>c__DisplayClass57_0.<RemoveUser>b__0()
at EPiServer.Common.Security.SecurityHandler.RemoveUser(IUser user)
As per above error, it seems like it is happening due to a DB issue. But what DB? How Can I diagnose? What could cause this? Any help appreciated. Thank you.
error This topic was created over six months ago and has been resolved. If you have a similar question, please create a new topic and refer to this one.
I have used,
To remove user.
Additional info:
