Calenderblock or similar in Epi CMS 11?
Is there any calender-block or functions to start from if you want to build a calender in Epi CMS version 11?
We want to build a calender in Epi CMS which you can add events to in Epi Backoffice.
/Br. Andreas
#200801
Jan 25, 2019 9:31
Might not be the approach that you are asking about but you could make use of something like the Scheduler from the Kendo UI tools: https://demos.telerik.com/kendo-ui/scheduler/index
#200809
Jan 25, 2019 16:00
I've also used blocks to feed data to the JavaScript calendar from https://fullcalendar.io/ as seen here https://dgs.virginia.gov/onthesquareVA/Calendar/onthesquarevacalendar/
public class CalendarItemBlock : BlockData
[Display(
Name = "Title",
Description = "Calendar Item Title",
Order = 10)]
public virtual string Title { get; set; }
[Display(
Name = "Description",
Description = "Calendar Item Description",
Order = 20)]
public virtual XhtmlString Description { get; set; }
[Display(
Name = "Start Date",
Description = "Calendar Item Start Date",
Order = 30)]
public virtual DateTime Date { get; set; }
[Display(
Name = "End Date",
Description = "Calendar Item End Date If Necessary",
Order = 35)]
public virtual DateTime EndDate { get; set; }
[Display(
Name = "Is All Day",
Description = "Event Is All Day",
Order = 40)]
[DefaultValue(true)]
public virtual Boolean IsAllDay { get; set; }
[Display(
Name = "Url",
Description = "Calendar Item Url",
Order = 50)]
public virtual Url Url { get; set; }
#200810
Jan 25, 2019 16:11
