CMS crashes when naming a block property ParentNode
Short version: the CMS crashes when you try to edit a block which has a PageReference property named ParentNode.
I'm upgrading an old project (from 6 R2 to newest version) and we're upgrading the old database. However since I have to change the name of ParentNode to something else, that property's data doesn't stick.
How to recreate:
  1. Start a new EPiServer project. Select empty project. I used .NET Framework 4.7.1.
  2. Create a block model inheriting BlockData that can probably be named anything you want.
  3. Create a PageReference (or ContentReference) property named ParentNode.
  4. Create the block. The CMS will just hang before it can ever load the block properties.
This is the blocktype I tested with:
[ContentType(
DisplayName = "Page List Block",
GUID = "9cb392be-3a46-40ea-99fd-a1b0c551eea7"]
public class PageListBlock : BaseBlock
    Display(
    Name = "Parent node",
    Description = "Parent page of the pages to be listed",
    Order = 100)]
    public virtual PageReference ParentNode { get; set; }
Any suggestions as to why this happens?
EDIT: This happens in two entirely different projects, so it's not a one-off thing.
#196539
Edited, Sep 03, 2018 15:30
Hi Vegard,
I think that you should raise a support ticket with support<at>episerver<dot>com.
#196547
Sep 04, 2018 1:41
As you say, done. Will see if I remember to post the solution here if there is one
#196566
Sep 04, 2018 14:52
Support created a bug report about it which is posted here: https://world.episerver.com/support/Bug-list/bug/CMS-11646
It has been marked "Closed, won't fix", with the note:
In other words, we just can't name a property ParentNode any more.
#196953
Sep 18, 2018 10:58
