(Alt Text) for images on EPiServer
Hello,
I am using CMS 7.5, and all I have for an image is the following:
Category
Copyright
Image Description
I cannot find (Alt. text) field for images, can you advise which field of the mentioned ones I can use for (Alt. text), and give me an example for alternative text for an image?
#196734
Sep 10, 2018 16:06
Hi Sherif Fadl.
Episerver relies on Content Types to accomodate assets, incl. images. You need to extend the Content Type of yours with a field to hold the alt text data value.
You can see an example here:
https://github.com/episerver/AlloyDemoKit/blob/master/src/AlloyDemoKit/Models/Media/ImageFile.cs
If you're unsure about where your Content Type for your image media is located within your solution, then try and do a search for MediaDescriptor - please look for one with the ExtensionString set to image extensions (like .jpg).
/Casper Aagaard Rasmussen
#196738
Sep 10, 2018 16:39
