Add button to TinyMCE and keep configured buttons?
We have built a TinyMce plugin that is installed via Nuget. We want to add an extra button to the toolbar but since it is a plugin we want to keep the configured buttons and just add our button last.
Everywhere I read it says that you must use Toolbar() to get the button to show.
            context.Services.Configure(config =>
                config.Default().AddExternalPlugin("myplugin", "/script/plugin.js")
                .Toolbar("myplugin");
Using this code will clear all buttons and just add mine. How do I keep all configured buttons and just add mine?
Thanks!
/Kristoffer
#197171
Sep 25, 2018 16:17
Hi. Have you tried adding in the names of the others after the name of your plugin like so:
.Toolbar(
                    "myplugin epi-link unlink anchor image epi-image-editor epi-personalized-content | superscript subscript | charmap | searchreplace | cut copy paste pastetext",
                    "numlist bullist outdent indent | alignleft aligncenter alignright alignjustify | table | row_props cell_props row_after row_before delete_row col_after col_before delete_col split_cells merge_cells",
                    "fullscreen | bold italic | hr | styleselect | formatselect | undo redo removeformat | code  mceEPiProcessDropItem"
#197176
Sep 25, 2018 16:41
@Kristoffer, use: AppendToolbar("myplugin") if you just want to add a new button at the end of the default toolbar.
When you use the Toolbar(".....") method you are setting the whole toolbar to those buttons (so as you are only setting your custom buttom to the toolbar you are effectivily clearing all the default buttons).
#197183
Edited, Sep 25, 2018 20:27
Hmm, I cannot find any AppendToolbar()?
But I solved it this way:
context.Services.Configure<TinyMceConfiguration>(config =>
    var defaultToolbar = config.Default()["toolbar"] as string[];
    if (defaultToolbar != null && defaultToolbar.Length > 0)
        var toolbar = defaultToolbar[0];
        toolbar += "| myplugin";
    config.Default().AddExternalPlugin("myplugin", "/scripts/editor_plugin.js")
                .Toolbar(toolbar);
Not the most clean way maybe but it works just fine. AppendToolbar() would of course be better. I'm using Episerver.CMS.TinyMCE 2.0, maybe AppendToolbar is included in later versions?
#197187
Sep 25, 2018 21:43
Upgrade to 2.3 then I found AppendToolbar(), thanks!
#197188
Sep 25, 2018 22:40
Hi Kristoffer, sorry, I originally assumed that you were naturally using the latest version of Episerver TinyMCE 2.x version.
Any reason why you don't update to the latest version 2.6.3? You would get some bug fixes, see the fixes here.
#197192
Sep 26, 2018 5:37
Since it it a plugin that should be available for all versions on CMS 11 in this case we don't want to use 2.6.3 but we are already using 2.3 which requires 11.3 so I guess that requiring 11.4.6 ins not a big step, I will upgrade!
#197205
Sep 26, 2018 9:12
Hello
I need a help to create custom mailto plugin in tinymce plugin.
Br,
Nilanjan Saha
#200292
Jan 08, 2019 16:17
