Trying to use the ContentReferenceList property but getting exception
I'm trying to use a very simple ContentReferenceList like this:
public virtual IList MediaFiles { get; set; }
But I am getting the exception:
System.NotSupportedException: The type System.Collections.Generic.IList`1[[EPiServer.Core.ContentReference, EPiServer, Version=11.9.3.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]] can not be mapped to a MetaDataType
Seems like this should be simple - so hopefully I've missed something obvious?
[I'm using Episerver CMS v11.9.3]
#196043
Aug 17, 2018 4:42
Well, that was a pretty silly post.. Forgot that this is on a Product so is the Commerce content provider which won't have compatibility for things like PropertyList! Oops, I'll leave this here for future me in case I do the same thing again :)
#196044
Aug 17, 2018 5:38
If you add the attribute
        [BackingType(typeof(PropertyContentReferenceList))]
To your property it will work. All the ILists work as long as you set the correct backing types so that commerce knows the correct meta data field to map to
#196051
Aug 17, 2018 9:52
Commerce contents have full support for IList<T> - well, except for inside blocks (which is coming soon). However you need to specify a BackingType as Scott said
#196053
Aug 17, 2018 10:13
Oh, in that case I’ll give that a try. I often run into weird limitations with Commerce content so just assumed this was another. Thanks Scott and Quan for the replies!
#196063
Aug 17, 2018 12:29
Just follow up message to say Scott and Quan were right :)
My property as follows works well:
[Display(
Name = "Media files",
Order = 130)]
[AllowedTypes(typeof(MediaData))]
public virtual IList<ContentReference> MediaFiles { get; set; }
Thanks again.
#196098
Aug 18, 2018 10:56
