TinyMCE 2.6.1 how to force update of customizations
Using the latest version of Episerver.CMS.TinyMce (v2.6.1 at the time of writing this), is there any way to force Episerver to reload the customizations?
Suppose I have the following:
context.Services.Configure(config =>
    var extendedSettings = config.Default().Clone();
    // Do lots of dynamic stuff; read from various files; etc.
    config.For(x => x.MainBody, extendedSettings);
This code runs the first time a TinyMce editor is rendered, and the resulting configuration is cached/reused when subsequent editors are rendered. What happens if one of my files changes, and I want to recalculate all of the TinyMce configurations? Is there a way to force that to happen without restarting the whole IIS site?
#196012
Aug 15, 2018 23:19
Hi Brian,
Maybe you could use Settings Transformations?
https://world.episerver.com/blogs/magnus-stalberg/Dates/2018/5/tinymce-configuration-api-news/
https://world.episerver.com/documentation/developer-guides/CMS/add-ons/customizing-the-tinymce-editor-v2/#setting-transformations
Then your code will look like:
context.Services.Configure<TinyMceConfiguration>(config =>
         .AddSettingsTransform("custom", (settings, content, propertyName) => {
    config.For<StartPage>(x => x.MainBody, extendedSettings);
#196041
Aug 16, 2018 20:13
Thank you! I think that is going to work quite nicely. I'm going to have to implement my own caching layer though, since this is called every time.
One thing I'm noticing: when I do this to modify the default settings and then refresh the bowser on all-properties view for a page that contains multiple XhtmlString properties, the first editor has the old configuration, while all the rest of them have the updated settings.
EDIT: Cancel that. I just realized that inside my settings transform I was making modifications to defaultConfig instead of the actual parameter settings. Funny thing- the API works a lot better when you use it correctly. embarassed
Example code:
    TinyMceSettings defaultConfig = config.Default().AddEpiserverSupport();
    defaultConfig.AddSettingsTransform("Custom", (settings, content, propertyName) =>
#196042
Edited, Aug 16, 2018 21:53
