Customizing the TinyMCE Table plugin attributes
Hi i am so much struggling with tinymce 2 can you help me understand  some modification on table. Fir starters how to add default CSS class to the table? When I add a table it should have a default CSS class e.g class="table" without any styles attributes. Currently when i add the table it comes with syles style="border-collapse: collapse; width: 100%;" border="1".
So how to remove these attribuets by default? Soeme one sugeested the following https://www.tinymce.com/docs/plugins/table/, but how can I use it in C# code?
#195039
Jul 11, 2018 17:46
Probably not the best way, but working for me.... I Can not really remember how I managed to find out this fix, but somehow does the border=1 interfere with the setting of a table class. I have set the border to 0, then the class propery can successfully be set
                config.Default().AddSetting("visual_table_class", "table");
                config.Default().AddSetting("table_default_attributes", new { border = 0 });
#195048
Jul 12, 2018 8:21
Per Jungnelius - Feb 03, 2021 15:47
Since this issue is closed I can't post an answer so I'll suffice with a comment.
For me setting "visual_table_class" to a non default value interfered with the edit experience of tables.
I eventually managed to use the "table_default_attributes" settings instead:
config.Default().AddSetting("table_default_attributes", new { Class = "table" });
(also paired with config.Default().AddSetting("table_default_styles", new { });
Thank you Sven that was really helpful
#195055
Jul 12, 2018 10:02
