Unable to paste blocks in "For this page"
Hello,
I received a bug task from one of our editors. When they try to copy a block from “for this page” folder  from one page and paste it in another (with the same type) page’s  “for this page” , it won’t work, they can´t paste the copied block , (it works only if there is already a block in the folder where you want to paste…wont work if the folder empty).
 Did anyone get the same problem?
Thank you.
#194542
Jun 25, 2018 9:42
I would like to add that when the "For this Page" folder never been used it has the type "Content Folder", but once you create a block in it it changes to "Content Assets Folder", and has a different ID.
#194560
Jun 25, 2018 15:03
We had the same issue on some projects in Episerver CMS 10, after upgrade to EPiServer.CMS.UI 11.1.0 issue was fixed.
Check the bug in the buglist: https://world.episerver.com/support/Bug-list/bug/CMS-8578
#194903
Edited, Jul 06, 2018 13:58
