It would help if you can post the fullstacktrace here. Also ClonedContentProvider is not a framework classs, is it from Alloy?
Correction: the exception is indeed thrown by a a provider in a subproject which happens to be made by one of our past staff members. I'm able to resolve the issue.
Many thanks for your help!
The full stacktrace is:
StackTrace " at EPiServer.Core.Internal.DefaultContentLoader.Get[T](ContentReference contentLink, LoaderOptions loaderOptions)\r\n at EPiServer.Core.Internal.DefaultContentLoader.<GetAncestors>d__24.MoveNext()\r\n at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source, Func`2 predicate)\r\n at EPi.Cms.ContentProviders.ClonedContentProvider.ClearCache(Object sender, ContentEventArgs e) in C:\\Waternet-GIT\\waternet-global-waternet\\src\\backend\\EPi.Cms.ContentProviders\\ClonedContentProvider.cs:line 429\r\n at System.EventHandler`1.Invoke(Object sender, TEventArgs e)\r\n at EPiServer.Core.Internal.DefaultContentEvents.RaiseDeleteEvent(String key, DeleteContentEventArgs eventArgs)\r\n at EPiServer.Core.Internal.DefaultContentRepository.Delete(ContentReference contentLink, Boolean forceDelete, AccessLevel access)\r\n at Waternet.Global.Waternet.Vacancies.VacancyRemovalJob.UnpublishAndRemovedExpired(IEnumerable`1 content)\r\n at Waternet.Global.Waternet.Vacancies.VacancyRemovalJob.Execute()\r\n at EPiServer.Scheduler.Internal.DefaultScheduledJobExecutor.<Execute>d__31.MoveNext()" string
As you can see ClonedContentProvider is part of your project. It might be doing something wrong in ClearCache. If you want to find out you would have to post your code here.
But I can guess that it listens to Deleted event to clear cache. At that point getting the content is too late as it was deleted. If you want to clear the cache, you should listen to Deleting event instead
Again, thank you very much. it did point me in the exact direction of where to look.
Hello,
I'm trying to make a scheduled job that deletes all the job vanacies we have after the have expired or have been unpublished.
When i try to remove the pages eventually the ClonedContentProvider throws a PageNotFoundException when trying to clear the cache.
Example of what happens here:
I hope someone can help me out
My gratitude in advance
[Pasting files is not allowed]
