IContent - I don't have an issue but I understand why.
Hi all,
Why does this works ?
[ContentType(DisplayName = "MyBlock ", GUID = "eccd619a-827c-4b13-b0c8-28c671f0f949", Description = "")]
public class MyBlock : BlockData
        [Ignore]
        public virtual string CmsBlockName
            get
                return (this as IContent).Name;
I looked everywhere and none of the ancestors of MyBlock implements IContent. So why am I able to get the name on the content block by doing this ?
#193971
Jun 08, 2018 18:11
All shared blocks will implement the IContent interface at runtime.
Local blocks won't.
If you call CmsBlockName on a local block, you'll get null reference exception.
I would suggest this code instead:
public static class BlockHelpers
    public static string GetName(this BlockData block)
        var content = block as IContent;
        return content?.Name;
#193972
Edited, Jun 08, 2018 18:21
Good to know! Thank you.
#193974
Jun 08, 2018 18:25
As Dejan points out is blocks a special kind of content in meaning they can both be a property on other content (local blocks) or be an own instance (shared block). Here is a post that describes how shared blocks are built up.
#193993
Jun 11, 2018 9:20
