Hello,
We have problem with accessing addon tab in EpiServer edit mode. It throws error about IDirectory after clicking the tab.
Could not load type 'EPiServer.Framework.FileSystem.IDirectory' from assembly 'EPiServer.Framework, Version=11.5.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
Probably we are missing some configuration as I saw that IDirectory interface in EpiServer 11 is now placed in EPiServer.Framework.AspNet.
Can you suggest me where to look for solution of the issue? Useful screenshots attached below.
AddOn Tab localization
error stack trace
Thanks in advance,
Tomasz Sanner
