Can't get a reference to a Block
If you have the following setup on the Episerver CMS: Variation Content -> Content Area -> Block.
When you're trying to publish the Block (or even delete it) there's aparently no way Episerver to know if that Block is being referenced anywhere.
The following options were tested:
- Getting a SoftLink to that Block using the method Load from the IContentSoftLinkRepository.
- Getting the References to that Block using the method GetReferencesToContent from the IContentRepository.
Is this a bug or am I doing something wrong?
#194467
Edited, Jun 21, 2018 17:55
Bump.
Anyone can help me with this please?
#194543
Jun 25, 2018 10:40
I guess that Variation Content is a commerce item? If so then you could try to ask the same question in the commerce forum.
#194556
Jun 25, 2018 13:31
Will do, thanks.
#194561
Jun 25, 2018 15:05
