How does your EditorDescriptor look like? And the configuration in module.config?
Editor descriptor:
[EditorDescriptorRegistration(TargetType = typeof(string), UIHint = UIHint)]
public class PushFormEditorDescriptor : EditorDescriptor
public const string UIHint = "PushFormEditorDescriptor";
public PushFormEditorDescriptor()
ClientEditingClass = "push/Editor";
Config:
<dojoModules>
<add name="tags" path="Tags" />
<add name="vimeo" path="Scripts/widgets" />
<add name="push" path="Push" />
</dojoModules>
Descriptor usage:
[EditorDescriptor(EditorDescriptorType = typeof(PushFormEditorDescriptor))]
[Display(Name = "Pushformulär",
Description = "",
Order = 5,
GroupName = "Information")]
public virtual string PushForm { get; set; }
Well I solved it by myself :) I missed the following override in the EditorDescriptor
public override void ModifyMetadata(EPiServer.Shell.ObjectEditing.ExtendedMetadata metadata, IEnumerable<Attribute> attributes)
Hello fellow developers!
Im currently trying to develop a simple dojo widget for EPiServer CMS v 9.4 but I have run in to some troubles.
The widget should contain a simple form, a button and a listing, but in the example below I have removed everything to just include the basic script and template, a minimal version that still does not work as it should
Script:
Template:
Solution based on example here: https://dojotoolkit.org/documentation/tutorials/1.10/templated/
The issue is that when I try to load a page in Forms Edit Mode where this is used, nothing happens. It simply shows the loading bar on the button, but I get no console errors, and the forms view does not display.
Anyone who have seen this strange behavior before and have a clue as to what causes it?
Best regards
William
