First, I would write the rule like this
<rule name="Redirect all hosts to https" stopProcessing="true">
<match url="(.*)" />
<conditions logicalGrouping="MatchAll">
<add input="{HTTPS}" pattern="off" />
</conditions>
<action type="Redirect" url="https://{HTTP_HOST}{REQUEST_URI}" redirectType="Permanent" appendQueryString="false" />
</rule>
Do you mean integration as in DXC Service?
If it is, it has SSL, all environments there have it, but if you have a custom DNS you need to fix the certificate yourself
Thanks , Yes DXC, we dont have ssl for the integration url just the production.
I have add the code in the web config and it still gives me a internal server error?
That is strange, we use DXC Service and we have SSL in integration, it is standard for the Azure-dns at least.
I changed my example to one that we use at a DXC Service solution that works in integration.
Maybe something else that is problem?
I have a web.production.config file that has the code to redirect to HTTPS:
When I deploy to integration (where there are no SSL's) I get a internal server error, not sure if this is right because of the none existant ssl's.
Unsure if i put it live is it going to cause an error on the live sites?
