504 Gateway error when saving block
I'm getting a 504 Gateway error when saving a block. The underlying error is manifesting as:
System.Web.HttpException: Version is not writeable
at EPiServer.Cms.Shell.UI.Rest.ContentChangeManager.UpdateContentProperties(ContentReference contentReference, IDictionary`2 properties, SaveAction saveAction)
at EPiServer.Cms.Shell.UI.Rest.Internal.ContentDataStore.Patch(PatchContentDataModel entity)
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.b__3d()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.b__3f()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<>c__DisplayClass2b.b__1c()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.b__1e(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
at EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult)
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
The block is quite standard and has the following standard property types:
1 int
4 strings
1 content reference (image)
1 bool
Any ideas?
Thanks in advance,
Mark
#191702
Apr 26, 2018 17:38
Can you post the code for your model?
#191774
Apr 27, 2018 14:34
