Unit testing - how to add blocks to a content area in a test project
Hi there,
We would like to unit test a validator that ensures a content area doesn't have two blocks inside it:
public class LandingPageValidator : IValidate
        public IEnumerable Validate(LandingPageDataModel instance)
            if (instance.HeroBlock.Count > 1)
                return new ValidationError[]
                    new ValidationError()
                        PropertyName = "Hero Block",
                        ErrorMessage = "Can only have one Hero Block"
            return Enumerable.Empty();
The problem we are facing is: how can we programatically add a second block to a content area, while inside the test project?
We have tried this approach: https://stackoverflow.com/questions/27993939/episerver-add-block-to-a-content-area-programmatically but that seems to work only in the main application (ContentReference.GlobalBlockFooter is null in the test project).
In case it helps, here is the data model.
public class LandingPageDataModel : BasePageDataModel
        [Display(
            Name = "Hero block",
            Description = "",
            Order = 140,
            GroupName = SystemTabNames.Content)]
        [AllowedTypes(new[] { typeof(LandingPageHeroDataModel) })]
        public virtual ContentArea HeroBlock { get; set; }
And here is what we have tried:
        [Fact]
        public void Validate_WhenHasMoreThanOneHeroBlock_ReturnsError()
            // Arrange
            var validator = new LandingPageValidator();
            var model = new LandingPageDataModel { HeroBlock = new ContentArea() };
            var item = new ContentAreaItem();
            model.HeroBlock.Items.Add(item);
            var expected = new ValidationError[]
            // Act
            var result = validator.Validate(model);
            // Assert
            Assert.Equal(expected, result);
However, it throws a null reference exception when we try to add the ContentAreaItem to the ContentArea (using model.HeroBlock.Items.Add). The exact error is:
System.NullReferenceException
Object reference not set to an instance of an object.
at EPiServer.Core.ContentArea.AddContentAreaItemsToFragments(IList items, Int32 startIndex)
#189244
Edited, Mar 14, 2018 8:23
Thanks @Johan! We had not read that. Will give it a go and update here.
#190543
Apr 11, 2018 18:08
