UI bug in new TinyMCE
dropdown opens under current window
#189762
Mar 23, 2018 16:52
Erik, Does browser choice make a difference?
#189773
Mar 23, 2018 19:57
I used chrome, haven't tested with other.
#189817
Mar 25, 2018 11:52
Hi, to add to this there is a bug also in the styles dropdown that I've posted to Ben McKernan blog comments. My issue is also when using the all properties view as is the case in Eriks report.
@Erik, have you tried does it work correctly in the OPE?
(@Bob, also the TinyMCE status bar is not visible in OPE but is visible in the all properties view, so if using OPE you cannot for exaple see the wordcount if you have added that plugin)
#189818
Mar 25, 2018 12:56
Hey. There is already a bug logged for this and we are currently working on it. https://world.episerver.com/support/Bug-list/bug/CMS-10102
#189881
Mar 27, 2018 10:05
An update. The issue is caused by TinyMCE and we have created a PR with a fix on their GitHub repository. Please go there and comment on the PR or related bugs if you are affected by this. https://github.com/tinymce/tinymce/pull/4297
I will update the bug description to reflect this.
#190246
Apr 06, 2018 8:35
